Marine Devices with a Chassis Ground Screw
Many Garmin® marine devices have a chassis ground screw to help prevent electrical interference. A marine-grade copper solid or stranded wire should be connected at the chassis ground and taken to the water ground. Examples of “water ground” could be found in different circuitry, wires, and connections to different systems of the vessel. Refer to the vessel's electrical distribution system to identify them or contact the vessel manufacturer. 1 Highly recommended for touchscreen devices. The chassis ground screw should not be connected to the to the voltage ground.
Bonding a marine device (chartplotters, sounder modules, e.g.) using the device's chassis ground provides some protection to the internal circuits and components from directly induced electrical currents.
NOTE: Bonding a marine device using the chassis grounding point may not stop or prevent damage caused by a lightning strike.
If a screw is needing to be replaced, below is a list of the screw sizes and corresponding units for each type and size of screw:
M3x0.5x4.0,PHP,SS/P,Nylon
echoMAP™ 7x chartplotters
ECHOMAP™ Ultra chartplotters
ECHOMAP™ Ultra2 chartplotters
GPSMAP® 7x1 chartplotters
GPSMAP® 7x2 chartplotters | GPSMAP® 9x2 (Plus) chartplotters
GPSMAP® 7x3 chartplotters | GPSMAP® 9x3 chartplotters | GPSMAP® 12x3 chartplotters
GPSMAP® 10x2 chartplotters | GPSMAP® 12x2 series (Plus) chartplotters
GPSMAP® 74xx series chartplotters |GPSMAP® 76xx chartplotters
GPSMAP® 84xx chartplotters | GPSMAP® 86xx chartplotters
- GPSMAP 16X3
M3x0.5x6.0,PHP,SS/P,Nylon
GMM™ 150 monitor | GMM™ 170 monitor | GMM™ 190 monitor
GPSMAP® 8xxx chartplotters
GPSMAP® 8500 black box | GPSMAP® 8530 black box
M4x0.7x5,PHP/S,SS/P
STRIKER™ 7 fishfinders| STRIKER™ 9 fishfinders
STRIKER™ Plus 7 fishfinders | STRIKER™ Plus 9 fishfinders
- STRIKER™ Vivid 7sv fishfinders | STRIKER™ Vivid 9sv fishfinders
M3x0.5x8.0,PHP LW/W
Garmin AIS™ 600 transceiver
VHF 100
VHF 200
VHF 300
VHF 300 Garmin AIS™
GPSMAP® 90xx chartplotters
GPSMAP® 92xx chartplotters
- GSD™ 28 sonar module
M3x0.5x10.0,PHP,SS/P,Nylon
GSD™ 24 sonar module
GSD™ 26 sonar module
M4x0.7x6,PHP,SS/P,w/Nylon
GMR™ 424 xHD2 radar | GMR™ 426 xHD2 radar
GMR™ 624 xHD2 radar | GMR™ 626 xHD2 radar
GMR™ 1224 xHD2 radar | GMR™ 1226 xHD2 radar
GMR™ 2524 xHD2 radar | GMR™ 2526 xHD2 radar
M4x0.7x8,PHP,SS/P,w/Nylon
- GMR Fantom™ pedestals
Terminal Ring, 18-14 AWG #6 Solid or Stranded Copper Wire Panduit-2176
- GLS™ 10 sonar module
1 On a marine vessel, the DC ground or electrical bond may also be referred to as a "water ground". Refer to the vessel's electrical distribution system to identify them.
