Automotive Device Not Detected by Garmin Express Software on a Mac
USB communication issues can prevent your Garmin device from being detected by Garmin Express™ software.
Verify no Other Garmin Applications are Running on the Mac
When Connected to a Mac, These Devices Will Only be Recognized or Detected by one Application at a Time
For example, if Garmin Express is open and has detected the device, opening Garmin BaseCamp™ software at the same time will result in BaseCamp being unable to find the device until both applications are completely closed and the desired application is re-opened.
NOTE: Devices with MTP Mode are prevented from appearing as a separate drive on a Mac computer.  For these devices, a Windows computer must be used.
To Force Quit Garmin Express or Garmin BaseCamp on Mac:
  1. Press Command + Option + Escape on the keyboard
  2. Select Garmin Express or Garmin BaseCamp™ from the list of applications
  3. Click Force Quit
Note: A second set of instructions may be required to force quit Garmin Express.
  1. Select the Triangle icon in the upper right corner and click Quit
  2. Click Quit again
The Garmin Express or Garmin BaseCamp program will now be closed.
To Keep Garmin Express From Opening when the Computer is Powered on or when a Garmin Device is Connected to the Computer:
  1. Click on Garmin Express by the Apple icon
  2. Click Preferences or Settings
  3. Remove the check mark from the following boxes:
    • "Always keep Garmin Express running in the background."
    • "Automatically launch Garmin Express when a Garmin device is connected."
Note: Removing the check marks will disable the ability for Garmin Express to automatically launch and perform syncs to a device using Garmin Connect.
Restart the computer after making these changes.
Follow the Instructions Below if the Device is Still Not Detected by Garmin Express
Video Instructions
To get started, watch the video walk-through below. Watching a video is the easiest way to learn how to get your device added to Garmin Express.
Verify the Device Displays the Connection Icon
NOTE: The device doesn't have enough power to communicate with the computer if the display is blank or only shows a Blank battery icon transparent battery icon when connected to the computer. Charge the device while driving using the vehicle power cable to ensure it has enough power.
Most Devices Will Display a Connection Icon on the Screen Indicating that the Device is Communicating with the Computer.
These icons vary, Some examples include:
Garmin devices plugged into a computer tower via USB cable
The Following Garmin Devices will not Display a Connection Icon:
  • Arctic Cat G8 Display
  • Camper 785 & Traffic caravan and motorhome sat nav with camera
  • Camper 890 caravan and motorhome sat nav
  • Camper 895 caravan and motorhome sat nav
  • Camper 1090 caravan and motorhome sat nav
  • Camper 1095 caravan and motorhome sat nav
  • Garmin Catalyst™ Driving Performance Optimizer
  • dēzl™ 780LMT-S GPS navigator
  • dēzl™ LGV800 | dēzl™ OTR800 GPS navigators
  • dēzl™ LGV810 | dēzl™ OTR810 GPS navigators
  • dēzl™ LGV1000 | dēzl™ OTR1000 GPS navigators
  • dēzl™ LGV1010 | dēzl™ OTR1010 GPS navigators
  • dēzlCam™ 785 LMT-S GPS navigator with camera
  • Garmin fleet™ 770 management
  • Garmin fleet™ 780 GPS management
  • Garmin fleet™ 790 GPS management
  • Kawasaki RIDGE 8" Tread Display
  • Overlander® GPS navigator
  • RV 785 & Traffic RV navigator with camera
  • RV 890 RV navigator
  • RV 895 RV navigator
  • RV 1090 RV navigator
  • RV 1095 RV navigator
  • Tread® - Overland Edition GPS navigator
  • Tread® - SxS Edition GPS navigator
  • Tread® XL - Baja Chase Edition GPS navigator
  • Tread® XL - Baja Race Edition GPS navigator
  • Tread® XL - Overland Edition GPS navigator
The Following Garmin Devices Require the Steps Below to be Seen by the Computer:
  • Camper 795 caravan and motorhome sat nav | RV 795 RV navigator
  • CamperCam 795 Motorhome Sat Nav | RVcam 795 RV Navigator with Built-in Dash Cam
  • Garmin Drive™ 53  | Garmin Drive™ 53 & Traffic | Garmin Drive™ 53 & Live Traffic GPS navigator
  • Garmin DriveCam™  76 GPS navigator with camera
  • Garmin DriveSmart™ 66MT-S | Garmin DriveSmart™ 76 | Garmin DriveSmart™ 86 GPS navigators
  • dēzl™ LGV610 | dēzl™ OTR610 GPS navigators
  • dēzl™ LGV620 | dēzl™ OTR620 GPS navigators
  • dēzl™ LGV710 | dēzl™ OTR710 GPS navigators
  • dēzl™ LGV720 | dēzl™ OTR720 GPS navigators
  • dēzlCam™ LGV710 | dēzlCam™ OTR710 GPS navigators with camera
  • dēzlCam™ LGV725 | dēzlCam™ OTR725 GPS navigators with camera
  • dēzl™ LGV820 | dēzl™ OTR820 GPS navigators
  • dēzl™ LGV1020 | dēzl™ OTR1020 GPS navigators
  • Tread® | Tread® - Base Edition | Tread® 2 GPS navigators
  • zūmo® XT2
1. Select Tap to Connect to Computer
    • If you do not select Tap to Connect to Computer this choice will eventually go away, you will then need to select Settings first.
2. Select Tap to Connect to Computer again
3. Select Continue
You should now see the connection icon.
Devices with Powered Mounts:
Connect the USB cable directly into your Garmin device and not into the powered mount. USB ports on mounts are for charging only.
Verify Your Mac Recognizes the Device
The System Information application on Mac can be used to verify the connection between a device and Mac. For instructions, see Verify the Physical Connection of a USB GPS Device to a Mac.
Device is not Recognized by the Mac
Try a Different USB cable
Mini-USB to USB-A cable  micro-USB to USB-A cable            USB-C to USB-A cable
Mini USB Cable             Micro USB Cable             USB Cable Type A to Type C
Ensure the USB Port is Working Properly
  • Try a different USB port on your computer and/or test the USB port with a different USB device.
  • Avoid connecting through a USB hub, USB extension cable, keyboard, or monitor.
  • On desktop computers, use the USB ports on the back of your computer.
  • Check for visible signs of damage to the USB port on the device such as a loose or sagging cable connection.
garmin device plugged into laptop with USB cable  usb cable plugged into back of desktop with USB cable
Laptop                         Desktop
Macs with only USB-C Ports:
Some newer Mac computers may only have USB-C or Thunderbolt ports. It is best to connect your device directly to the computer when possible. If your device has a USB-C port, you can use a USB Type C to Type C data transfer cable. Apple has a helpful support article that explains different USB types, how to identify them, and what adapters can be used: Identify the ports on your Mac and Adapters for the Thunderbolt 4, Thunderbolt 3, or USB-C port on your Mac.
Macs with M1 and Newer Chips and USB-C Ports:
Automotive devices with miniUSB or microUSB ports must use a USB-C to USB adapter along with the appropriate miniUSB to USB-A or microUSB to USB-A cable provided with the device.
Automotive devices listed below may need to use a USB 2.0 third-party hub in order for the Garmin device to properly detect the USB connection.
  • BMW Motorrad Navigator V and VI
  • Camper 760 caravan and motorhome sat nav
  • Camper 780 caravan and motorhome sat nav
  • Can-Am Spyder zūmo® 590LM
  • dēzl™ 560 GPS navigator
  • dēzl™ 760 GPS navigator
  • dēzl™ 770 GPS navigator
  • dēzl™ 780 GPS navigator
  • dēzl™ LGV500 | dēzl™ OTR500 GPS navigators
  • dēzl™ LGV700 | dēzl™ OTR700 GPS navigators
  • dēzlCam™ LMTHD GPS navigator with camera
  • Garmin Dash Cam™ 45
  • Garmin Dash Cam™ 46
  • Garmin Dash Cam™ 47
  • Garmin Dash Cam™ 54
  • Garmin Dash Cam™ 55
  • Garmin Dash Cam™ 56
  • Garmin Dash Cam™ 57
  • Garmin Dash Cam™ 65W
  • Garmin Dash Cam™ 66W
  • Garmin Dash Cam™ 67W
  • Garmin Dash Cam™ Mini
  • Garmin Dash Cam™ Mini 2
  • Garmin Dash Cam™ Tandem
  • Garmin DriveLuxe™ 50 GPS navigator
  • Garmin DriveLuxe™ 51 GPS navigator
  • Garmin Fleet™ 600 series
  • Garmin Fleet™ 700 series
  • Garmin Speak™ with Amazon Alexa
  • Garmin Speak™ Plus with Amazon Alexa with Built-in Dash Cam
  • Harley Davidson Roadtech zūmo® 590LM
  • nūviCam™ LMTHD GPS navigator with camera
  • RV 760 RV navigator
  • RV 780 RV navigator
  • zūmo® 590 GPS navigator
  • zūmo® 595 GPS navigator
    Macs with Other Types of USB Ports:
    Connecting through a hub, USB extension cable, adapter, keyboard, or monitor is not recommended or supported.  Use the product compatible USB cable to connect directly to the computer.
    Restart the Computer and Try Again.
    1. Click the Apple icon in the menu bar
    2. Click Restart...
    3. Click Restart to confirm
    Garmin Device is Recognized by the Computer but not by Garmin Express
    Ensure Garmin Express is Up to Date
    Current Version of Garmin Express for Mac: 7.25.0 as of March 25, 2025.
    1. Open Garmin Express
    Garmin Express icon of globe with orange tear drop around it
    2. Click Garmin Express in the Apple menu bar
    3. Click About Garmin Express
    4. Click Check for Updates to Express
    5. Click Install Now if prompted
    The latest version of Garmin Express can also be downloaded and installed from the Garmin Express page.
    Remove the Device and Add it Back Again if your Device has Already been Added to Garmin Express
    Remove the Device
    Garmin Express globe logo
    2. Hold Control (Ctrl) on your keyboard, and click the device when using a one-button mouse on a Mac
    3. Click Remove from Express
    4. Click Remove
    The device will be removed from Garmin Express.
    Re-add the Device
    2. Connect a new device or ANT stick to the computer
    3. Click Add Device
    Add a Device plus sign icon
    4. Click Add Device when the device is found
    5. Follow the on-screen prompts to add the device to Garmin Express
    You can try a different Admin User if the issue continues. Contact Apple for instructions.
    See the Following Related Troubleshooting FAQs:
