Understanding and Using the Respiration Widget on the Enduro 2
The Respiration widget glance will display your breaths per minute. This is measured by using your HRV (Heart Rate Variability) as measured by the heart rate sensor of your watch.1 You can use this widget to track your breathing all day, or while sleeping.
The average respiration rate while resting is between 12-20 BRPM (Breaths Per Minute). During activities, BRPM can be much higher, between 40-50 BRPM.
IMPORTANT: Garmin wearables are not medical devices, and the data provided by them is not intended to be utilized for medical purposes and is not intended to diagnose, treat, cure, or prevent any disease. Garmin recommends you consult your doctor before engaging in any exercise routine.
Adding the Respiration Widget
  1. Hold UP/MENU.
  2. Select Appearance.
  3. Select Glances.
  4. Select +Add.
  5. Select Respiration.
  6. Select where you would like the widget to display.
You can now see your breaths per minute by viewing the Respiration Widget on your watch.
Example:
Image of Respiration Widget
1 Activity or movement can impact the ability of your watch to read HRV using the OHR (Optical Heart Rate) sensor and will result in the watch not being able to read your breaths per minute. For this reason, an HRM-Pro, HRM-Run, HRM-Tri, or HRM Dual is required to capture respiration data during an activity.
