Troubleshooting the Garmin Dog Widget with a Compatible Watch and Pro 550 Plus
The Pro 550 Plus can transmit dog tracking information to compatible outdoor watches1.
NOTE: Fenix watches require that the DogTrack Widget is enabled. To find the Owner's Manual for your specific product, see FAQ: Finding the Owner's Manual for a Garmin Device
Devices transmitting dog tracking information can transmit to multiple devices at a time. For example, the Pro 550 Plus can transmit to a fenix 3 and fenix 5 at the same time.
Troubleshooting Steps for the Dog Tracking Widget on a Watch
If the feature is not working properly with the any of the Broadcast mode compatible devices, use the troubleshooting steps below to resolve the problem.
  • Ensure all devices are on latest software version.
    • View Related Content at the bottom of the page for instructions.
  • The transmitting device and receiving device must be within 15 feet of each other (closer is recommended for testing and troubleshooting).
  • Ensure you are actively communicating with a compatible dog collar on the Pro 550 Plus.
  • Ensure only the two devices that should be communicating are on (power off all other transmitting handhelds).
    • The handheld device always has ANT+ broadcasting enabled.
  • Power off then power back on the transmitting and receiving device to ensure they are no longer looking for any previously paired devices.
  • Forget the previously paired handheld to ensure the watch is not looking for a different device.
    • On the watch dog tracking widget:
      1. Press the Start/Stop button.
      2. Select Forget Transmitter.
      3. Give the widget a few minutes to detect the handheld.
  • If other compatible receiving devices are available, try transmitting to them to see if they will pick up the signal.
1 For a full list of compatible outdoor wearable devices see: Garmin Watches That Have the Dog Tracking Widget
Related
