Enabling Auto Pause on the Forerunner 35 is performed either on the device or in Garmin Connect only for the following activity types:
Bike
Run Indoor
Run Outdoor
Select one of the options below to view instructions:
To Enable Auto Pause on the Watch
Press
Select Activity Profile.
Press
Highlight Auto Pause and press
Press
to to turn on.
To Enable Auto Pause in the Garmin Connect App
Open the Garmin Connect app.
Access the menu by selecting More (bottom right).
Select Garmin Devices.
Select Forerunner 35.
Select Activity Profiles.
Select Bike, Run Indoor, or Run Outdoor.
Tap on Auto Pause toggle switch to enable Auto Pause.
Sync the device to apply the changes.
To Enable Auto Pause in Garmin Connect
Sign in to Garmin Connect.
Select
in the top right corner.
Select on Auto Pause toggle switch to enable Auto Pause.
Select Save Settings.
