Rename the VIRB X or XE Wi-Fi name
When pairing the VIRB X or XE with Wi-Fi to a compatible smartphone, it will show the device’s Wi-Fi name. The default name is usually VIRB and a four digit number.
To change the VIRB Camera Wi-Fi name:
- Power on device
- Press and hold the Menu button.
- Select Wi-Fi
- Select Edit
- Select SSID
- Use the Arrow buttons and OK to select the new Wi-Fi name.
The entered name will now be what appears when trying to pair with the smartphone.
If you have multiple cameras to pair to the same Wi-Fi source, it may be difficult to differentiate one device from another. Changing the SSID can help better identify individual devices.
