Using Different Map Datum to Search for Coordinates on Automotive Devices
Your device allows you to search for coordinates using a different map datum.
To Change the Map Datum Format:
  1. Touch Where To?
  2. Touch Coordinates
  3. Touch Format
  4. Touch Datum
    • Skip this step on some devices
  5. Select the desired map datum from the list
  6. Touch OK
Your device will now allow you to search in the datum of your choice. Repeat the above steps if and when a different map datum is required.
