Manually Entering and Saving Coordinates as a Waypoint on a Touchscreen Rino
Coordinates for a specific location can be entered manually and saved by creating a waypoint and editing the location field on a Rino® 610, 650, 650t, 655t, 750, or 755t outdoor handheld.
Creating a Waypoint With Known Coordinates
  1. Navigate to the main menu.
  2. Touch Mark Waypoint.
  3. Touch Save and Edit.
  4. Touch Change Location.
  5. Use the highlighted arrows to select the character you would like to change.
  6. Use the number pad to select new numbers or use the arrows to select letters.
  7. Repeat steps 5 and 6 as necessary.
  8. Touch the green check mark.
  9. Touch the red X.
The coordinates will now be saved as a waypoint in the internal memory of the device.
