Changing the Pin Location on an Approach G80
Even if you keep the golf courses up-to-date on your Approach® G80 golf device, you can still find that the pin location has moved. The Approach G80 device gives you the ability to relocate the pin on any hole, so you can get accurate distance to the pin.
Changing Pin Location
Note: To change pin location, you must have started a round of golf on the Approach G80 device.
- When viewing a hole during a round, touch
- Touch anywhere on the green to place the pin
- Touch
to return to the hole information
The pin location is saved only for the current round.
