Garmin Dash Cam 30 or 35 display continually dimming
Garmin's Dash Cam devices have a setting which will automatically dim the display of the device after a period of inactivity. The device will continue to record video even while the screen is dimmed (indicated by a red light), provided the SD card remains in the device and the device remains powered on.
To enable or disable the Display Timeout setting:
- Press the button next to the down arrow
to access the menu
- Press the button next to the check mark
when Settings is highlighted
- Press the button next to the down arrow when Display Timeout is highlighted
- Press the up or down arrow until desired display timeout is highlighted
The device's display can be set to time out after 1 minute of inactivity, or the display timeout can be turned off.
