Problems Between a Garmin Chartplotter Using NMEA 2000 with Suzuki Engines
A loose connection inside the Suzuki engine harness sometimes causes problems between a Garmin chartplotter connected to a Suzuki engine.
A white wire in the Suzuki engine harness has a bullet connector. This connector can sometimes be loose or disconnected, impacting the NMEA 2000 network. Contact Suzuki for support in correcting the issue.
