Purchasing Outdoor Maps+ in the Alpha App
With an Outdoor Maps+ subscription¹, you gain access to a wide variety of premium global mapping content. This content is regularly updated and the one subscription can be activated and downloaded directly to any of your registered compatible Garmin devices simultaneously via WI-FI.
To access Outdoor Maps+ content, you must have a compatible device. To check device compatibility before purchasing see - Compatible Garmin Devices.
Before you can purchase an Outdoor Maps+ annual subscription through the Garmin Alpha® app, you must first pair a compatible device.
To pair a compatible Garmin device:
  1. Open the Alpha app.
  2. Allow any app permissions when prompted.
  3. Sign in with your Garmin account or create an account.
  4. Place your Garmin device in pairing mode.
  5. Select Devices Alpha Devices Tab.
  6.  Select  Alpha add device.
  7. Select the device from the list.
  8. Continue with on screen prompts.
Once paired in the app, to purchase your Outdoor Maps+ Subscription.
  1. Select Devices Alpha Devices Tab.
  2. Select the Outdoor Maps+ compatible device.
  3. Select Outdoor Maps+.
  4. Follow the on screen prompts to make your purchase.
Once the activation completes, you can proceed with downloading Outdoor Maps+ content to your compatible Garmin device.
(Activation will complete on its own shortly after purchase).
¹Subscription can be purchased annually or monthly.
Related
