Update and Learn About Software for the MARQ Collection
Keeping your software up to date will ensure that you get the best performance and latest features, which are listed in the What’s New? section. Methods for updating software are described below.
For information on updating compatible mapping, see Related at the bottom of the page.
What's New?
System Software June 2024 Release [Version 27.00]
We are frequently adding bug fixes, and at times, new features with the latest software updates.New Features
- Added Device Settings Backup and Restore.
- Added manual SW updates using Wi-Fi (compatible models only) to the settings menu.
- Added the ability to check for software updates via Bluetooth.
- Added CIQ App Rating to all CIQ Types (no longer restricted to "Apps" only).
- Added tracking of splits for Ski.
- Added support for 100hz sensor rate for CIQ apps.
- Improved quality of randomness of music shuffling (Pro models only).
- Improved display of ski/snowboard activity summaries to exclude chairlift data.
- Updated software backup to display a message when backup is from an incompatible source.
- Removed the limitation on the number of points allowed in a course.
- Fixed an issue with alarm tones not activating when an activity is set to max battery.
- Fixed an issue where some Russian, Ukrainian, Bulgarian, and Greek text would not display properly.
- Fixed an issue where the Indoor Bike Activity would default to the first set of data fields.
- Fixed potential issue where the “Safety Features Enabled” notification would continually be displayed.
- Fixed an issue where devices would not play a tone nor vibrate after acquiring GPS in an activity.
- Fixed an issue when pairing to new CT10 golf club types.
- Fixed an issue to ensure training load is properly calculated when using the Store & Forward feature on supported Garmin HRM straps.
- Fixed an issue where the device would sometimes shutdown when viewing the map on the Fish activity.
- Fixed an issue with audio prompts on workouts not playing the correct messages.
- Fixed an issue with auto runs on the Ski activity from not always starting on a descent.
- Fixed an issue with auto pause on the Ski activity from improperly activating.
- Fixed an issue where the menu to create a course would not display properly.
- Fixed an issue where sport devices would shutdown when attempting to create a backup.
- Fixed an issue causing lap cadence spikes in swim.
- Fixed an issue that would sometimes cause smart notifications to not display properly.
- Fixed an issue where the device would shutdown when creating a custom course.
- Fixed an issue where LiveTrack would stop tracking after 24 hours.
- Fixed an issue where eBike-related data fields would show incorrect data.
- Fixed an issue where the text displayed on the Breathing Activity would sometimes be blank.
- Fixed missing ski/snowboard distance in the All Stats section for those activities.
- Fixed an issue with CIQ apps that would sometimes cause the device to shut down.
- Fixed an issue with swimming activities where the distance data would be stuck at zero.
- Fixed an issue where the Backcountry XC activity would have duplicate data screens.
- Fixed an issue where the Sync Failed message would display even if a sync was successful.
- Fixed an issue that would cause Sport devices to occasionally shutdown.
- Miscellaneous bug fixes and improvements.
Installing Software Updates
Garmin Connect™ App
The Garmin Connect app will download software updates automatically behind the scenes while your watch is connected to your mobile phone. There are no steps required for you to take to get the latest software. Generally, any released updates will take up to a week to download before automatically, or prompting, to install on your device.Search for, and download, the Garmin Connect app in your phone's application store to get started. For more information on the Garmin Connect app, see - Garmin Connect app on Garmin.com.
Garmin Express™ Software
Garmin Express software provides the ability to check for, and download, software updates each time you connect your device to the computer.
For information on downloading Garmin Express software and using it to update your device, see - Using Garmin Express to Update Your Watch's Software.
Manually Checking for Updates From the Watch
Your Garmin watch can check for the latest software updates, while connected to the Garmin Connect App or through Wi-Fi®.
To manually check for updates, do the following:
Press and hold UP/MENU (middle left button).
Scroll to or select
Settings.
Select System.
Select Software Update.
Select Check for Updates.
While connected to Wi-Fi your watch will use it to check for updates. Otherwise checking for updates will default to using Garmin Connect.
Want Early Access to New Features or to Test New Software?
Garmin has public beta program that allows you to gain early access to new features, software updates, and bug fixes. You can find more information, and instructions for enrolling in the beta program, by visiting Enrolling in Garmin Beta Software Program.Benefits to enrolling:
- Early access to new features and bug fixes.
- Access to dedicated forum community for discussing beta software and bug reports.
- Ability to provide direct feedback about products or features you are passionate about.
