My Watch Is Having Trouble Detecting Move IQ Events
The Move IQ® automatic activity detector allows your Garmin® watch to automatically detects certain types of exercise such as biking, running, swimming, walking, or using an elliptical machine. Continuous movement of at least 10 minutes will tag an exercise as an event. If you have a situation where a particular exercise is not being recognized, ensure the following:
  • Exercise must be continuous and last at least 10 minutes
  • Exercise is one of the Move IQ event identified types
  • Device is being worn on the wrist
Steps to Enable or Disable Move IQ Automatic Activity Detection:
Select an option below to reveal steps for your Garmin Connect™ account:
Garmin Connect App
  1. Open the Garmin Connect app.
  2. Select More (bottom right).
  3. Select Garmin Devices.
  4. Select your device.
  5. Select Activity Tracking or Health & Wellness.
  6. Toggle the Move IQ button to enable or disable.
    • To Enable: toggle button to the right (blue).
    • To Disable: toggle button to the left (grey).
Garmin Connect Web
NOTE: Devices compatible with Real Time Settings will not be able to make changes using Garmin Connect web. See steps above or refer to your owner's manual
  1. From a web browser, sign into your Garmin Connect account.
  2. Select Watch icon to open the device list.
  3. Select your device.
  4. Next to your device, select Device Settings.
  5. Select the Activity Tracking tab.
    • To Enable: toggle button to the right (green).
If an exercise is being missed and not tagged as a Move IQ event, it is likely due to the movement being outside of our algorithm detection.
If you have a situation where a Move IQ event is being detected repeatedly when you are not performing that exercise, we recommend that you disable the Move IQ feature from your Garmin Connect account.
See Related below to learn more about the Move IQ feature.
Related
