Radio Page Functions on the Rino 600 Series
The radio page provides the user interface for Family Radio Service (FRS) and General Mobile Radio Service (GMRS) radio operations.
Channels
The Rino® outdoor handheld has a total of 30 channels and 121 squelch codes.
Channel | Frequency |
1-7 | GMRS and FRS channels |
8-14 | FRS channels |
15-22 | GMRS channels |
15R-22R | Repeater channels |
GMRS frequencies are regulated by the FCC. In order to transmit on GMRS frequencies, you must obtain a license from the FCC. For more details, see - GMRS and FRS Setting on Rino Series.
Choosing a Channel
From the main menu, select Radio.
Select Channel.
Use + or - to select a channel.
Scanning Channels
You can scan the channels for voice activity by selecting Radio > Scan.
Setting Up a Scan List
You can pick which channels and codes to scan. Selecting specific channels and codes reduces the scan time and helps prevent missing a transmission.
Select
Select Setup Scanlist.
Select channels to add.
Monitoring for Activity
You can monitor a single channel for any activity, including static and weak voice signals. This is helpful if a signal is going out of range.
Select Monitor.
