Why can't I Connect my SiriusXM Tuner to my 700 Series?
FUSION has identified an issue with the current SiriusXM connector utilized on the FUSION 700 Series Marine Entertainment Systems. The connector on the MS-IP700 or MS-AV700 is not compatible with the SiriusXM tuner. FUSION has created an interface adapter that will correct this problem. Do not attempt to connect the SiriusXM tuner to your marine stereo without using this new interface adapter as it can cause physical damage and void the warranty of the SiriusXM tuner.
