Save Part of a zumo's Track Log as a Route
Your zumo device has the ability to convert previously traveled trip data into a route for future use.
To save a segment of your Trip/Track Log as a route:
  1. Touch Tools
  2. Touch User Data
  3. Touch Manage Trip Log
  4. Touch Save As Route
  5. Touch the segment of the log you wish to convert to a route
Once calculated, you can touch Map to see the route that the unit created. You can touch Share to save the route to an SD memory card to share with other zumo users. You may also edit the route to change the points on it or touch Go! to start the route you created from the trip log.
