"No Detailed Maps" or "No Map Data" Error Message on Kenwood System
If the error message "No Detailed Maps" or "No Map Data" appears on a Kenwood navigation system, follow the steps below to verify the mapping is enabled.
To Verify the Mapping is Enabled:
- Touch Nav or Navigation
- Touch Settings from the Where To? and View Map screen
- Touch Map or Map & Vehicle
- Touch myMaps or Info
- The next screen will display the installed map. Verify there is a check mark in the box next to the map.
- If there is no check mark present, touch the box to put a check mark in it.
Putting a check mark in the box will enable the mapping and resolve the error message.
If there is a check mark in the box and the error message appears or you are unable to put a check mark in the box, take the vehicle to a dealer for assistance.
