Using Route Planner on the Monterra
A Route is a sequence of waypoints or locations that leads you to your final destination. Using the Route Planner on the Monterra® outdoor handheld:
Creating A Route
- From the menu select Route Planner.
- Select
- Select
again.
- Select a category.
- Select the first point in the route.
- Select Use.
- Select
to add additional points to the route.
- Select
to save the route.
Editing the Name of a Route
- From the main menu select Route Planner.
- Select a route.
- Select Name.
- Enter the new name.
Viewing a Route on the Map
- Select a route.
- Swipe left to view the map.
Editing a Route
- Select a route.
- Use one of the following options:
- To view a point on the map, select a point.
- To change the order of points on the route, drag points up or down in the list.
- To add an additional point to the route, select
- To remove a point from the route, hold the point, and select
Reversing a Route
- Select a route.
- Select
- Select Reverse Route.
Deleting a Route
- Press and hold the selected route.
- Select
