Replacement Watch Bands for Garmin epix Pro Gen 2 42mm Watches
A replacement band can be ordered on Garmin®’s website to update the look of your watch or replace a band.
The watch bands that fit your epix™ Pro (Gen 2) - Standard Edition 42mm or epix™ Pro (Gen 2) - Sapphire Edition 42mm can be found using the link below:
Finding Bands at Garmin.com
  1. Hover over the Sports & Fitness menu at the top Garmin.com.
  2. Select a product type.
  3. Select your watch from the list.
  4. Click on Accessories.
  5. Click on Bands.
You will now see a list of compatible bands for your watch.
If your watch is not listed here, you may need to use the search box located in the upper right-hand corner of the Garmin.com home page.
