Using the Same USB Flash Drive for the Honda Map Update
When performing a Honda map update, the same USB flash drive used for a previous map update may be used.  The USB flash drive needs to be completely formatted before using it for the new update.  See Formatting a USB Drive for a Honda Navigation System for instructions on formatting.
Once the flash drive has been formatted, follow the full update process found at https://honda.garmin.com/honda/
