Note: The device can be unplugged normally if the screen shows the orange connection icon
Follow the below steps if the device shows the gray connection icon:
There may be a problem with the mapping files if the message “No Detailed Maps Found That Support Routing” is displayed after turning on an automotive device. The message “No Map Data Available” may display when searching for a destination. This may cause the device to show only the locations of major cities or major highways with no side streets.
For “No Detailed Maps Found That Support Routing” - if it cannot be dismissed by pressing OK or the back button, press and hold your finger on the message to clear it.
If the device displays "Can't Unlock Maps" after clearing the message, follow the instructions in Correcting the Message "Can't Unlock Maps" or "Can't Authenticate Maps" on a Garmin Automotive Device.
For “No Map Data Available” - Ensure the map is enabled on the device by following the steps below.
1. Touch Settings
2. Touch Map & Vehicle
3. Arrow down and touch myMaps or Configure Maps
4. Enable the maps
See Formatting a microSD/SD Memory Card for instructions.
Safely remove your device from the computer after the update has completed. The write-caching feature on some computers may not have completely built or transferred the map to the device even though the update appears to be complete. Safely removing the device before unplugging it can prevent this problem from happening.
See Maps Missing After Updating Maps on a Full Coverage Automotive Device for additional troubleshooting.
