Transferring GPX Files From Monterra to a Mobile Device
You can transfer GPX files, such as waypoints or tracks, from your Monterra to a mobile device via Bluetooth. This is helpful if you want to pull up the GPX file within another app on your mobile device, or you want to share files with others.
Note: As the Monterra is an Android device, this transfer only works to another Android mobile device.
Transferring GPX Files from Monterra
  1. Select the GPX file
  2. Select Android Share
  3. Select Image of the Bluetooth Icon Bubble
  4. Bluetooth Device Picker will list Bluetooth-enabled devices in range. Select the Android device you want to share the GPX file with
    • You may see a pop-up on the Monterra that it's sending the file to the selected device
  5. Select Accept on the Android device
Another pop-up on the mobile device should appear when the file has been received, the file can then be found in My Files. If unsure how to access My Files, reach out to the mobile device manufacturer for assistance.
