You are viewing an article that is not available in your currently selected language. You can choose another one below.
Disable ecoRoute
To disable ecoRoute:
  1. Touch Tools
  2. Touch Settings
  3. Touch Navigation
  4. Touch Automobile or Car
  5. Touch nuRoute
  6. Touch Calculation Mode
  7. Touch an option other than Less Fuel
  8. Touch Save
The ecoRoute feature will now be disabled on your device, but your vehicle profile will still be present. Follow the steps above to turn ecoRoute back on.
The ecoRoute feature can also be disabled by restoring the device to factory default settings.
Note: This will clear all user settings but should leave saved locations and recently found items intact.
To restore the device to factory default settings:
  1. Touch Tools
  2. Touch Settings
  3. Touch Restore
    • Some devices require you to touch the menu button (three horizontal lines) prior to this step
  4. Touch Yes to confirm
The vehicle profile will be cleared and ecoRoute disabled.
