Updating the Cortex™ M1 Hub and Handset
Cortex® receives regular software updates. Updates unlock new features and functionality in Cortex, but importantly they address software performance. Updates are downloaded via the Cortex Onboard™ App via the Apple App Store or Google Play. See Related Content for detail on the latest software releases.
We often have customers with issues during the update, which are often only not allowing enough time for the update to complete.
Just to explain the upgrade process:
  • When the update begins, all the lights are green. This takes around 8 minutes from an iPhone/Android phone The device will upload the new upgrade file and the Cortex will then validate it
    It's best to only have one device (iPhone or Handset) connected, not multiple. If upgrading from an iPhone, it's best to keep the app open on the update screen
  • Once the uploaded file is validated correctly, Cortex will then reboot. The LEDs will turn blue, starting with the GPS LED, then as the upgrade progresses all the LEDs go blue. This takes around 3-4 minutes
  • Once the upgrade is finished the normal boot process occurs the yellow/green LEDs will appear again
The total time should take less than 20 minutes. But typically around 12 minutes.
If there is an issue connecting, remove the NMEA 2000 cable and turn off/on the Cortex and try connecting again.
Updating Cortex® M1 Hub Firmware via Android and iOS
Check the Apple App Store or Google Play Store for updates to Cortex Onboard, select UPDATE as required. (The Onboard app will also notify when an update is available when it is on an internet connection.) The software update is passed to cortex from your cell phone or tablet and then to the handset.
Once the update is downloaded to the mobile device, connect it to the M1 Wi-Fi on the vessel.
The M1 will automatically recognize updated firmware.
The Onboard App will ask if you would like to perform the firmware update. Select Yes to update.
Follow the instructions on the Onboard App.
Updating Cortex HUB (M1) firmware
Firmware updates for the M1 hub and H1/H1P handsets are bundled with Cortex Onboard App releases. Check the Google Play Store or Apple App Store for updates to Cortex Onboard and select UPDATE, if available.
For more about what to expect from the update, see Related Content.
Once downloaded to the mobile device, follow these steps
1. Connect the mobile device to the M1 Wi-Fi on the vessel
2. Press the Wi-Fi icon
Trying to Connect
             3. Press the Config Icon
             Cortex Wifi Network
             4. Press select, and the device will look for the QR code
5. Point the camera at the QR code that is in the box with the  M1
Cortex Password
             Once the app has connected, it should ask to confirm the update. If not, do the following:
              1. Push the menu icon (top left) and then
              2. Push the center of the top banner
              3. Select Cortex Updates...
               Cortex Updates
              The M1 hub will automatically recognize updated firmware and the Onboard App will ask to perform the firmware update. Select Yes to update and the status bar will indicate the update status.
              Ask Later Image
 NOTE: If the Cortex is registered, emails will advise when a firmware update is available.
