ECG App Results Are Not Showing Up in Garmin Connect
Check the following items to ensure that your Garmin Connect™ account settings are enabled to upload and display ECG app recordings.
Upload Consent
You must enable activity upload and Data Storage & Processing for ECG app results to sync to your account. To enable these settings:
  1. Open the Garmin Connect app.
  2. Select More (bottom right).
  3. Select Settings.
  4. Select Profile & Privacy.
  5. Select Data.
  6. Select Device Upload and then select the toggle switch to enable.
  7. Select Storage & Process and Agree
If you revoke consent at any time, all previously uploaded ECG recordings will be deleted from Garmin Connect.
Enable Two-Step Verification
You must enable two-step verification for your Garmin Connect account. To do so, go to Garmin.com/account, log in with your username and password, select “Update sign-on settings,” and follow the instructions to enable two-step verification.
Related
