(2023) Service Bulletin 23111 Rev A: G3X Touch™ EFIS Software Version 9.16
PRODUCTS AFFECTED:
G3X Touch systems installed using Approved Model List (AML) Supplemental Type Certificate (STC) SA01899WI are affected.
CERTIFICATION AUTHORIZATION:
STC SA01899WI MDL Revision 16
COMPLIANCE:
Optional: This Service Bulletin may be incorporated at the owner’s discretion and is not warranty reimbursable.
DOCUMENTATION CONSIDERATIONS:
As a result of changes related to this update, the applicable documents listed in Table 1 are required to be issued to the aircraft operator/owner before the aircraft is returned to service.
Document TitlePart NumberRevision (or later)
Garmin G3X Touch EFIS Part 23 AML STC Maintenance Manual Contains Instructions for Continued Airworthiness190-02472-029
Airplane Flight Manual Supplement or Supplemental Airplane Flight Manual for the Garmin G3X Touch Electronic Flight Instrument190-01754-016
G3X Touch Pilot’s Guide for Certified Aircraft190-02472-00F
PURPOSE:
This STC amendment approves the following:
NOTE
These LRUs are updates to the existing GEA 24 and GMA 245R equipment, and can be used for new installations or to replace the original part numbers in existing installations.
  • Interface between the GEA 24(B) and SureFly TACH2 module to allow G3X to read and display engine RPM from a SureFly Ignition Module (SIM).
WARRANTY INFORMATION:
This modification is not warranty reimbursable.
