Unable to See All the Pictures Downloaded to an Automotive Device
If you are not able to view all the pictures on your device, the most likely cause is that the pictures are not in the correct file format. The Garmin GPS is only able to display pictures that are in JPEG (Joint Photographic Experts Group) format. The file will have an extension of .jpg. An example of the file name would be "picture.jpg". If the picture file is not in this format, it will need to be converted. After the conversion, download the picture file to the GPS and it will be able to display the picture.
