Select Manually Enter Coordinates or Select a Waypoint.
Manually Enter Coordinates:
Type in the coordinates.
Press the X button.
Select More on the location page to add a name to the location created, or edit it.
Select a Waypoint: Choose a Waypoint saved on the device.
Requesting Weather Forecasts With an inReach SE or Explorer
The inReach SE® and inReach Explorer® devices are able to request Basic, Premium, or Marine weather forecasts for viewing on the inReach® device. This article will cover how to request weather forecasts from the inReach device only. For information on requesting weather using the Earthmate® app, see - Requesting Weather Forecasts with the Earthmate App.
Important Notes
For more information about Basic, Premium, and Marine weather, see - Frequently Asked Questions on Weather for inReach.
A marine forecast will be included for locations on an ocean or other large body of water, if available. If you are unable to get a marine forecast, select a location further from shore.
Requesting weather forecasts is only available to inReach SE or inReach Explorer devices loaded with the 2.11 or later firmware version. If you do not have an option for Weather, see Updating inReach Firmware and Syncing Account Changes with inReach Sync for instructions on updating your device with the latest firmware release.
Requesting a Weather Forecast
Select Weather.
Select My Location, or select New Location for a weather forecast of a different area.
Change the selections for Basic, Premium, or Marine forecasts, if desired:
Select Get Forecast.
Select Get Forecast to confirm.
Example Weather Forecasts
Basic Land Forecast
Marine Forecast
For examples of other weather related icons, see - Frequently Asked Questions on Weather for inReach.
