Using a Wired Headset with an Automotive Device
Your automotive device allows you to connect a wired headset for receiving phone audio1 and voice prompts. The device has a 3.5 mm headphone audio jack, either on the device or on the mount, to which a wired headset can be connected.
Note: The device supports Bluetooth wireless technology, but it cannot transmit audio to both the Bluetooth and wired headset connections at once. When your device is paired to a Bluetooth headset, the audio will be sent through Bluetooth instead of the wired headset. If you want to hear the audio in a wired headset, you must have the Bluetooth headset unpaired.
1Phone calls through wired headsets are not available for the zumo 395LM; a Bluetooth headset must be used.
