How Do I Activate a Subscription Service on my Forerunner 945 LTE?
The Forerunner® 945 LTE watch has certain features (such as LiveTrack over LTE, spectator messaging over LTE, and safety features over LTE) that require an LTE subscription. To activate an LTE subscription, select a scenario below:
Add LTE During Initial Setup:
  1. Open the Garmin Connect™ app.
  2. Access the menu by selecting More (bottom right).
  3. Select Garmin Devices.
  4. Select the Forerunner 945 LTE.
  5. Select Finish Setup1.
  6. Select Set Up LTE.
  7. Follow the prompts in the app to select a service plan and complete the setup.
After you set up your LTE subscription, you will receive an email when the activation has been completed.
If you receive an error message when trying to set up your LTE service, see:  Error Message When Trying to Activate Subscription Service
Add LTE After Completing Setup:
  5. Select Connectivity.
  6. Select LTE
  7. Select Set Up LTE.
  8. Follow the prompts in the app to select a service plan and complete the setup.
What LTE Subscription Plans are Available?
For information on current LTE subscription plans, features, and pricing, see: Garmin Smartwatch Subscription Plan.
1If you do not see Finish Setup you will need to walk through the steps here:  Remove and Add a Device From the Garmin Connect App
Related
