Missing Where To?/View Map Widget on an Automotive Device
Your device has a customizable home screen. The widgets can be moved to different places on the home screen or removed completely. If you have accidentally removed the Where To? and View Map menu, it can be replaced.
To Replace the Where To? and View Map Widget:
1. Hold your finger down on the home screen in the empty space
2. Touch Widgets
3. Scroll down to the Garmin Navigation section
4. Touch and hold Where To?/View Map
    • On the Camper/RV 785, dēzl™ 780, and dēzlCam™ 785, the default widget is labeled 6 x 3
      • If you'd like a smaller one, choose the widget labeled 6 x 2
    • The Camper/RV 890, Camper/RV 1090, dēzl™ LGV/OTR800, and dēzl™ LGV/OTR1000 only have one widget option
5. Drag the widget to the desired place on the home screen
You will now have the option to select "Where To?" or "View Map" from the main menu screen.
