Share Routes and Favorites via Memory Card (SD Card) with a Harley Davidson Road Tech zumo 660 or 665
You can share your saved routes and favorites with other Harley-Davidson Road Tech zumo 660 and Harley-Davidson Road Tech zumo 665 owners via a memory card (SD card).
To share routes via memory card:
  1. Touch Where To?
  2. Touch Custom Routes
  3. Select the routes you want to share
  4. Touch Share
  5. Touch Export
  6. Touch Memory Card
  7. Touch Ok
  8. Remove the memory card and insert it into another zumo device
    • A message appears asking you to import the shared route
  9. Touch Routes
  10. Select the routes you want to import
  11. Touch Import
  12. Touch Ok
The routes will now be imported to the device.
To share favorites via memory card:
  1. Touch Where To?
  2. Touch Favorites
  3. Select the favorite you want to share
  4. Touch Share
  5. Touch Export
  7. Touch Ok
    • A message appears asking to import the new information
  9. Touch Favorites
  10. Select the favorites you want to import
  11. Touch Import
  12. Touch Ok
The favorites will now be imported to the device.
