Using the Multisport Activity Profile on a Garmin Watch
The multisport profile on Garmin® watches will record multiple activities as one session. When viewed in your Garmin Connect™ account, you can view the overall event or the detailed metrics for each individual activity. Select a topic below to view it's details:
Once you select a multisport activity, you will be prompted to select an activity type. Depending on the multisport activity you select, your options for which activity profiles you can select will vary.
NOTE: Not all activity sport profiles may be available.
When recording a multisport activity, you can transition to the next sport segment when you are ready. Each individual sport will be recorded separately, but when saved will appear as part of the entire multisport activity.
Select a multisport activity.
Press START/STOP to start the activity timer.
Press BACK/LAP to start and end each transition.
The transition feature is on by default, and the transition time is recorded separately from the activity time. The transition feature can be turned on or off in the multisport activity settings. If transitions are turned off, press BACK/LAP to change sports.
After you completing the activity, press START/STOP and select Save.
Auto Transition
This feature is available on select Garmin watches and automatically detects sport changes between Swim, Bike and Run in multisport activities. To enable or disable this, follow the steps below.
Hold MENU.
Select Activities & Apps.
Select the activity's settings.
Go to Auto Sport Change and press START/STOP to turn On or Off.
Some Garmin watches feature the Change Sport hot key option that can allow you to switch activity profiles while recording an activity, and save it as one overall multisport activity. Using the Change Sport hot key does not have built in transition periods like the Multisport profile, but can be useful if you do not know the types of activities you will be doing in advance.
Using the Change Sport Hot Key During an Activity
Start an activity.
Hold the Change Sport hot key.
You will need to set up Change Sport as a hot key. For instructions on adding this, refer to your owner's manual.
Press START/STOP to select your next activity from the list.
Repeat Step 2 and Step 3 as needed for each new activity.
When finished, press START/STOP to stop recording.
After completing and saving the activity, it will be saved as a multisport activity to the watch. It can then be viewed as a multisport activity on the watch and in Garmin Connect once you have synced.
Alerts, data fields, and other sport specific settings within the multisport activity profile are controlled by the sports that are selected for each activity.
For example: if Run is the profile selected for your first activity you would set what alerts you want to see using the Run profile.
You can disable all alerts from the profiles selected in the multisport profile within the activity settings.
Press the START/STOP.
Select your multisport profile.
Press and hold UP to open the menu.
Select Triathlon Settings. (This will be the name of the selected profile.)
Select Alerts to toggle it to either Allow or Do Not Allow.
After you have synced the activity to your Garmin Connect account, you can view the details of your multisport activity. You will see an overview of the entire activity but can choose by the individual sport to see data recorded for that specific sport.
Select the activity that you wish to see the details of.
The activity will display an overview of the entire multisport event. Since different sports have different types of data recorded, the multisport overview will only display some of the activity data in the summary. If you wish to see more details from the event (swim strokes, cycling speed, run cadence, etc) you will need to select a specific sport or transition to view the detailed summary data that is relevant to that portion of the multisport event.
Select Activities from the navigation bar on the left.
Select All Activities.
Select the title of the activity you wish to see the details of.
NOTE: You can also select the icon in the filter bar to select only multisport activities.
When viewing a multisport activity in Garmin Connect web, there are different options you can select to view different types of summary data. When you have selected, this will display an overview of the entire multisport event. Since different sports have different types of data recorded, the multisport overview will only display elevation and heart rate in the summary data. If you wish to see more details from the event (swim strokes, cycling speed, run cadence, etc) you will need to select a specific sport or transition to view the detailed summary data that is relevant to that portion of the multisport event.
