How Do I View Sensor Information In Garmin Connect?
Sensor accessories that were used with a Garmin Devices in the last 90 days can now be viewed in the Garmin Connect™ app and online. The sensors page will show the battery status and when this was last checked.
NOTE: Dual-sided Garmin power meters will reflect battery status based on the side with the least amount of battery.
Garmin Connect App
NOTE: If you cannot find the Sensor section and you have had a sensor connected to a Garmin device within the last 90 days, please check for an update to the Garmin Connect app
  1. Open the Garmin Connect app.
  2. Access the menu by selecting More (bottom right).
  3. Select Garmin Devices.
  4. View Sensors.
Screenshot with a red outline box highlighting what sensors are paired to a device.
Garmin Connect Web
  1. Sign into Garmin Connect from a personal computer.
  2. Select black watch icon on a white background(top right).
  3. View Sensors.
Red box outlining section in Garmin Connect web showing what sensors are paired to a device.
