How to Improve Distance Tracking on Indoor Activities
If the distance recorded during indoor runs or walks is not accurate, here are some tips for best results.
  • Record a few runs or walks outside with GPS.
    • Make sure you get the GPS ready indicator before starting the timer on your calibration activity.
    • Choose a location without trees or tall buildings for the best GPS signal.
  • The calibration activity should be recorded at similar pace to your regular pace and should be at least 1 mile in length.
    • If your pace is slower than 27 minutes per mile or 1 meter per second or the cadence is less than 80 full steps per minute the device may not be able to generate enough data for a proper calibration.
  • Ensure you have the correct values set in the User Profile of the device. For details see, Changing Device and User Settings in Garmin Connect.
  • Calibrate the watch by performing a Treadmill activity. The watch must record a distance of at least 1 mile (for older models) or 1.5 miles (for newer models) before it will give the "Save and Calibrate" option. For more details, see your owner's manual.
    • NOTE: Some older watches do not have the option to calibrate via treadmill. In these cases, run at least 1 mile outdoors with GPS enabled to complete a calibration.
    • Your arm should be allowed to swing naturally during the calibration activity. Do not hold the handrails of the treadmill.
  • Use an additional sensor like a foot pod, HRM-Pro™ Plus, HRM-Fit™ or HRM 600 heart rate monitor. To see if your watch supports wireless sensors, refer to your owner's manual.
Related
