Viewing Navionics Maps on an Earthmate PN-Series GPS
Follow the instructions below to make sure Navionics® Chart maps are viewable on the Earthmate® PN-Series GPS.
1. Install the latest firmware for the Earthmate PN-Series GPS.
2. Power off the PN-Series GPS and insert the Navionics SD card into the devices’ SD card slot.
3. Power on the device and the message in the image below will display.
4. From the Home Page, select the Map icon and press ENTER to open the Map Page.
5. Select the Map icon in the main screen and press ENTER.
6. On the Map Page press the MENU button.
7. In the Map Menu make sure Turn Charts Off is displayed.  If not, select Turn Charts On and press ENTER.
8. In the Map Menu select Map Setup... and press ENTER.
9. Select Navionics Setup... and press ENTER.
10. Select the field under Chart and press ENTER.
11. Select a chart in the list and press ENTER.
12. Select View Chart and press ENTER.
13. Your chart should now be visible on the Earthmate PN-Series GPS.
