Instructions to Sync Spotify Music to a D2 Mach Series Watch
Requirements
The following are requirements to use the Spotify Connect IQ™ app on your watch:
The watch must be paired to your smartphone through the Garmin Connect™ app.
The watch needs to be set up to connect to a secure Wi-Fi network. For help, see - .
A Spotify Premium subscription is required. For help, see Spotify's website.
I Meet the Requirements. What Do I Do Next?
The three steps listed below need to be completed when first setting up the Spotify app with your watch. Once complete, you will only need to follow the third step when you want to load additional content to your watch. Select each section to expand and view instructions on completing each step:
Step 1: Download and Install the Spotify Connect IQ App
On the watch, press START to access the activity and app list.
Select Connect IQ Store.
Select Recommended.
Scroll to and select Spotify.
Press START to confirm and install the app.
Once the Spotify app finishes installing you are ready to move to Step 2.
If the Spotify app is not listed under recommended apps, it can still be installed via the Connect IQ store on the web using the steps below.
Message should indicate that the app will be installed during the next sync. If this does not occur automatically, below are options to sync your watch:
To sync via Bluetooth®: Be in range of your paired Smartphone, press and hold the power key to access the Controls Menu. Select to sync.
To sync via Wi-Fi: Be in range of your Wi-Fi network, press and hold the power key to access the Controls Menu. Select to sync.
To sync using Garmin Express™: Connect the watch to a computer using the supplied power/data cable. Open Garmin Express. Sync will automatically occur once the watch is detected.
Once the sync is complete, the Spotify app will be installed onto your watch. You are ready to move to Step 2.
Step 2: Set Up the Spotify Connect IQ App
Press and hold Down.
Next, you will be prompted to select your music provider. Press Down.
Select Spotify.
You will now be prompted to open the Garmin Connect app.
From the Garmin Connect app, you should see a Spotify login prompt.
Enter your Spotify login details and select LOG IN.
Review and agree to the terms by selecting AGREE.
Return to your watch and select Get Started.
Choose the option to Add music & podcasts.
From this point you will be able to choose saved Playlists, Recently played, Made for You, Workouts, or Podcasts. Proceed to Step 3 to get some music set up to send to your watch.
Step 3: Selecting and Syncing Content to the D2 Mach Series Watch
The watch must be able to connect to your Wi-Fi network to download content from Spotify. Content available to sync to the watch will be listed under Your Library from your Spotify account. This includes:
Playlists: Saved or created playlists
Recently Played: A list of tracks that you have recently played
Made for you: New Music and Daily Mixes based on your listening habits
Podcasts: Saved podcasts
If Downloading Music for the First Time
On the watch access the Music Controls (press and hold DOWN).
Select Add music & podcasts.
Choose a category then choose the content you want to sync to your watch.
If You Have Already Downloaded Music on the Watch
Press .
Select Library icon .
At this point, the watch will attempt to connect to your Wi-Fi network to sync music. Syncing music will require a lot of battery power so we recommend plugging the watch into a charger near the Wi-Fi router for the best results.
