Automotive Device Calculating Routes Slowly
Some Causes for the Device Calculating Routes Slowly:
NOTE: When using the zūmo® XT2 GPS navigator, Tread® GPS Navigator and all models in the Tread® series, it is recommended to use the Tread® App for managing waypoints, routes, and tracks. BaseCamp can be used to manage waypoints and tracks, but BaseCamp does not support route creation for the Tread devices. BaseCamp is not compatible with the zumo XT2 or Tread 2 models.
Trying to route to an area where there are no route-able roads.
Routing to an area where there are no detailed maps loaded to the device.
The route entered is simply too long for the device to calculate.
A route is created in the BaseCamp™ software and sent to a device that is not compatible.
The device has reached its maximum available memory for the route that is being calculated.
One of the Following Errors May Also Display:
"Cannot Calculate Route".
"Unable to Calculate Route to destination".
"Route Too Long".
"Unable to Calculate Route: No roads near destination".
"Route Memory Full".
"Route Calculation Error: Not Enough Memory Available".
See the Troubleshooting Below if the Device is Calculating a Route Slowly or Displaying an Error Message:
Ensure the compatible device is up to date by reviewing the Software section under your device in Support Center for instructions.
Verify the correct map region is installed to the device by visiting the Support Center, entering your product name, and searching for "Verifying Maps Installed on an Automotive Device"
If a cross country trip is entered, enter the destination(s) for just that day, rather than the whole trip. The device may have problems calculating a route over 500 miles all at once.
If a route with multiple stops is entered using Trip Planner, Route Planner, or the Routes feature, it may take longer to calculate the route depending on how many stops there are. We suggest breaking up the route into multiple legs or a different trip for each day. Note: not all devices have Trip Planner or the Routes feature.
The myTrends feature may also slow down route calculation. The myTrends feature will predict routes based on repeated travel to the same destination. Steps for disabling the myTrends feature can be found in the owner's manual for the automotive device. See How myTrends Works on Compatible Automotive Devices for more info.
- Note: Not all devices will have this feature.
Devices that record a trip log will archive these tracks or trip logs. These files can end up being quite large if traveling across great distances.
To Delete Archive Files on the Device Using a Computer:
Windows:
Connect the device to a computer
Click on the Start button
Click on My Computer, Computer or File Explorer
Press Windows key + E (Windows 8, 10, 11)
Click on This PC (Windows 10 or newer)
Double click to open the Garmin Device drive
Open the GPX folder
Some devices will require you to open the Garmin folder, Internal Storage, or Internal Garmin storage first
Open the Archive folder
Delete the contents of this folder
Mac:
NOTE: Files cannot be viewed from the devices listed in Automotive Device Compatibility with Garmin Mac Applications on macOS when connected to a Mac computer.
Double click to open the GARMIN drive
Open the GPX folder
Some devices will require you to open the Garmin folder first
Empty the contents of the Trash
The archive files will now be deleted.
