Below is a list of articles that will help you get started with, and get the most out of, your new Garmin MARQ® Expedition watch.
How Do I Get Started?
You can follow the below instructions for the process to setup your Garmin MARQ Expedition watch.
Before getting started, we recommend that you fully charge your MARQ watch. See Charging the Device to learn how.
| 1. Power on the MARQ by holding the Light button. | Click Here to Learn About the Buttons
| 2. Choose your language by scrolling through the list, use with the UP to select your language. |
| 3. Pair your watch with your smartphone following the on-screen instructions (optional). | Click Here for Help With Bluetooth Pairing |
| 4. The next steps allow you to set your user preferences, simply follow the on screen prompts in the Garmin Connect App. |
| 5. Select your favorite types of activities to finish setup (optional). | Click Here to Learn How to Set Your Favorite Activities- Locate your activities by using the Up or Down buttons to scroll through the list
- Press UP button to select the activities
- Use the Down button until you see Done on the screen
- Press UP button to save your selections
- To start using activities, see: How to Start an Activity
Tip: If you want add activities later, see How to Add an Activity to the Garmin MARQ Expedition
Other Articles You Might Find Useful
