How to Install Connect IQ Content Using the Garmin Connect App
Connect IQ™ apps can be downloaded and installed from the Connect IQ Store using the Garmin Connect™ app on a smartphone.1
Installing Connect IQ Apps Using the Garmin Connect App
Open the Garmin Connect app.
Select More (bottom right).
Select Connect IQ Store.
Sign in (if requested) using your Garmin Connect credentials and select your device if prompted.
Choose an app to install, then select Download.
Review and Accept Terms if required.
Grant permissions (if required) by selecting Allow.
Exit Connect IQ store and Sync device to install the Connect IQ apps.
Once installed on the device, you may need to configure your device to use the Connect IQ app.
1 Certain requirements must be met to access the Connect IQ Store. Apps will only be available for Connect IQ compatible devices. When using a mobile device, Garmin Connect app must be installed, and the device must be paired (connected) in order to manage Connect IQ apps. For more on mobile device compatibility, see Related Content below.
