Exit Services feature on your dezl 560
Exit Services is a feature that allows you to view important Points of Interest (POIs) that are located at exits along an active route that is on a major highway/interstate.
To access Exit Services on your device:
- Touch Where To?
- Touch Exit Services
- Touch the desired category
- Available categories are Fuel, Food, Lodging, Rest Areas, and Weigh Stations
- If a category is grayed-out, POIs in that category are not present at the selected exit
- Touch the desired POI
- Touch Go! to navigate to the selected POI
- Start New Route clears your active route and sets the selected POI as the final destination
- Add to Active Route adds the selected POI as a via point and leaves the final destination intact
Repeat the steps above as needed.
