Customizing the Data Fields on the Arctic Cat G8 Display
Your device allows you to customize the data fields on the navigation screen.
To Change the Data Field:
1. Touch Map
2. Touch the data field that does not display Speed
3. Touch "+" next to the desired option to save the change
This selected data will now be displayed in the data field while driving.
It is possible to add additional data fields on the map by enabling the Trip Data map tool on the device.
To Enable Trip Data:
1. TouchMap
2. Touch the in the lower right corner
3. Touch Trip Data
Additional data fields will appear on the right side of the screen. You can customize these by touching any one of them, then touching the + icon next to the desired data type, which will automatically change the type of data displayed.
Your device offers the following customizable data field options:
Available with or without routeAvailable during active route only
  • Fuel Level
  • Coolant Temperature
  • Engine Hours
  • Voltage
  • Intake Air Temperature
  • Exhaust Temperature
  • Hand Warmer
  • Thumb Warmer
  • Maximum RPM
  • Temperature
  • Direction
  • Elevation
  • Max. Elevation
  • Time of Day
  • Sunrise / Sunset Time
  • Recorded Track Distance
  • Recorded Track Time
  • Total Moving Average Speed
  • Total Average Speed
  • Total Max. Speed
  • Total Stopped Time
  • Total Moving Time
  • Total Time
  • Trip A
  • Trip B
  • Location
  • GPS Accuracy
  • Arrival Time
  • Time to Destination
  • Distance to Destination
  • Next Stop Arrival Time
  • Time to Next Stop
  • Distance to Next Stop
  • Distance to Turn
  • Time to Turn
  • Off Course
