Collections Manager on the Montana 700 Series
The Collections Manager allows you to select which Collections are active on your Montana® 700, 700i, 710, 710i, 750i, or 760i outdoor handheld when synced with the Garmin Explore™ app. This helps to organize what user data is visible on your device.
For more information on Collections, see -  Garmin Explore Collections
The total amount of data in the Collections on the Montana 700 series handhelds is limited by the capacity of the device.
Accessing and Using the Collections Manager
  1. Select Home to reach the main menu.
  2. Select Collections Manager
  3. The Collections that have been synced to the Montana will display with additional information and options.
    • Number of waypoints, tracks, routes, activities, and courses are listed for each Collection.
    • If it says No Collections found, your handheld needs to be paired and synced with the Garmin Explore app. For steps, see Related.
      • To enable or disable an individual Collection, select the toggle for it:
        • Montana Toggle Up: Collection is enabled and the user data is listed and usable on the handheld.
        • Montana Toggle Down: Collection is disabled and the user data is hidden on the handheld.
      • To enable or disable all Collections, select 3 Lines Menu Symbol and Enable All or Disable All.
Enabling or Disabling a Collection
When you enable or disable a collection(s), the data contained within it will either be available or not available within its respective menu:
  • Tracks under Saved Tracks
  • Waypoints under Waypoint Manager
  • Routes under Routes Planner
  • Activities under Recorded Activities
  • Courses under Course Planner
NOTE: If your syncing settings are set to Sync Everything in the Garmin Explore website or app, the Library cannot be disabled in the Collections Manager on the device. Data that is in a collection will still be visible even with the collection disabled in the Collections Manager. For steps on adjusting syncing settings, see - Setting a Primary Collection With the Garmin Explore Website or App.
Related
