Connect the Rino handheld to the computer using a USB/Data cable.
Open the Garmin Express program.
Select the Rino handheld.
NOTE: If this is your first time using Garmin Express, see - Adding and Removing Devices in Garmin Express.
Select IQ Apps.
Select Get More Apps.
Choose an app, data field, or widget to install, then select Download.
When choosing Connect IQ content, the content will be labeled with one of the following icons:
Apps
Data Fields
Widgets
Review and Accept Terms if required.
Grant permissions (if required) by clicking Allow.
From the Garmin Express program, select IQ Apps.
From the dropdown menu in the upper right, select All.
Select
next to the content you wish to install.
Review and accept any prompts for Terms and Conditions or Important Notes.
Once complete, disconnect your Rino handheld from the computer.
Installing and Viewing Connect IQ Content on the Rino 750, 750t, and 755t
Connect IQ™ apps, data fields, or widgets can be downloaded and installed from the Connect IQ Store to your Rino® 750, 750t, or 755t handheld by using the Garmin Express™ program. Once loaded, apps, data fields, and widgets are all accessed from different sections on the handheld.
Apps, data fields, and widgets are all accessed from different sections on the handheld. When installing connect IQ content, the content will be labeled with one of the following icons:
Apps
Data Fields
Widgets
Apps
NOTE: Rino® handhelds use Classic Mode by default, but the mode for these devices can be changed going to the app drawer and selecting Setup > System > Mode.
Classic Mode
From the home screen, swipe up to access the app drawer.
Select Connect IQ.
Select an app.
Activity Mode
From the home screen, select IQ.
Select an app.
Data Fields
From a page that displays data fields, select a data field.
NOTE: To enable customizable data fields on the map page, select
> Setup Map > Dashboard > Large Data Field or Small Data Fields. Select
or
near the top of the map to show or hide the data field(s).
Select Connect IQ.
Select a data field.
Widgets
Swipe down from the top of the screen.
Swipe left or right to scroll through the widgets.
- Select
to return to the previous screen.
