How do I Install/Replace the microSD Card in my fleet 780 or fleet 790?
Access to the SD card may be required in the event the microSD card needs to be replaced or removed from the device.
To install or replace the camera microSD card:
1.  Remove the two Phillips head screws using a #1 Phillips head screwdriver
    • View figure #1 to locate the two screws
2.  Insert the microSD card into the right-most slot
    • View figure #2 to locate the slot
    • To replace the existing memory card, press in the memory card in until it clicks and remove it from the slot
3. Press in on the microSD card until it clicks
4. Replace the panel, tighten the screws, and power on the device
