MAC Crashes and Reboots When Trying to Connect Over USB
Starting with Mavericks (Mac OS X 10.9), Apple has included FTDI drivers with their system. As such, if all you're using is vmAIS, there's no need for a separate install of the FTDI driver anymore. For Mac OS X 10.3 to 10.8 you will need to download and install a separate FTDI driver, which can be found here.
If there happens to be a separate FTDI driver installed and loaded, accessing the COM port can cause a system crash.
To fix this, run the attached script. To run the script "right click" (click with two fingers) -> Open With -> Other... -> Utilities (down the list) -> Terminal.app. The attached pdf describes the steps being performed by the script and also provides the instructions for manually fixing the issue.
removeFTDIDrivers.sh    1 KB
TB_Mac_USB_Drivers.pdf    100 KB
Related
