dezl Headset Not Powering on or Charging
Check the Following if a dēzl™ Headset Will not Power on or is Not Charging:
- Verify the headset is receiving power from the connected USB cable.
For charging information for the dēzl™ Headset 100 and dēzl™ Headset 200, see Charging the Device
- For charging information for the dēzl™ Headset 110 and dēzl™ Headset 210, see Charging the Device
The power LED flashes green when the headset is charging.
Note: Charging the headset will power it on, and it can be used while charging. The headset will charge while powered off.
Inspect the power LED.
For LED activity and status information for dēzl Headset 100 and dēzl Headset 200, see Status LEDs.
- For LED activity and status information for dēzl Headset 110 and dēzl Headset 210, see Status LEDs.
If the LED is solid red, the headset has detected an error or fault that prevents the battery from charging.
Try another charging cable.
Try another charging adapter.
Try another power source.
Note: The maximum expected life for phone calls only with normal usage is up to 50 hours for the dēzl Headset 100 and dēzl Headset 200, and up to 60 hours for dēzl Headset 110 and dēzl Headset 210. Maximum expected life when used for media is up to 25 hours for the dēzl Headset 100 and dēzl Headset 200, and up to 35 hours for dēzl Headset 110 and dēzl Headset 210. Using Active Noise Cancellation will decrease these estimates.
See Turning Active Noise Cancellation On or Off for instructions to enable or disable this feature for the dēzl Headset 100 and dēzl Headset 200.
See Turning Active Noise Cancellation On or Off for instructions to enable or disable this feature for the dēzl Headset 110 and dēzl Headset 210.
