Configuring Keys on the Rino 750 and 755t
On the Rino® 750 and Rino® 755t outdoor radios you can configure both the User and Power key.
Configure Keys
- From the Main Menu, select Setup
- Select System
- Select Configure Keys
- Select Power Key or Call Key
- Select Single Tap, Double Tap, or Hold (Call Key only)
- Select available options
If you are customizing the Power Key option, either Single Tap or Double Tap must be Status Page. If the Single Tap option is currently set to Status Page and it is changed to another option, Double Tap will automatically be changed to Status Page.
Available Options
- Data Screens (Call Key Single Tap only, disables Double Tap)
- Call (Call Key Single Tap only)
- Menu Item:
- Applications
- Shortcuts
- Setup
- Where To?
- Status Page
- Main Menu
- Flashlight On/Off
- Screen On/Off
- Take Picture
- Log Geocache
- Start/Stop Track
- Lap
- Emergency Alert
- None
