Sending a Location With a Rino 520/530
You can send any location that you have available in your Find menu. These may be waypoints, contacts, cities, exits, or any other data that is loaded in the unit. Below are the steps to send a waypoint.
To Send a Location (Waypoint) Using Find
  1. Press the Thumb Stick In and hold it until the Shortcuts Menu is displayed, or press the Page button until the Main Menu is displayed.
  2. Highlight Find and press the Thumb Stick In.
  3. Highlight Waypoints and press the Thumb Stick In to display the list of waypoints nearest to your current location.
  4. Highlight the waypoint that you want to send and press the Thumb Stick In to display the Waypoint Review page.
  5. Highlight the Option Menu button rino 520 menu and press the Thumb Stick In.
    Rino 520 Send Location
  6. Select Send Location and press the Thumb Stick In.
The location is sent to all Rino® outdoor handhelds using the same channel and code. They can then choose to Go To that location, view the location on the map (Map), or save the location (Save).
